![]() | Home > Technical (L405) > Stop start not functioning 2016 4.4 SDV8 |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 669 ![]() ![]() ![]() |
My MY16 was fairly similar and on the original batteries, stop start worked occasionally after a long run but no other symptoms. I changed both, probably a side affect of being a previous L322 owner and now my stop start always works!
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1417 ![]() ![]() |
I wish mine didn't work |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
easy solution,
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
Me too, ![]() |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Hi Stan,
understood..
I do indeed have the auxiliary battery.
just to clarify,
JLR battery prices are quite competitive at the moment sir... ![]() |
Yes Stan, I've an 019 main battery under the spare wheel which shows as 'replace battery' on the midtronics tester.
I will make enquires, thanks Craig |
New main battery fitted this afternoon, BMS reset and away we go.
