Home > Maintenance & Mods (L322) > Dead battery recharge on or off
993porky
England 2004 Range Rover HSE Td6 Java Black
Hi all
I have dead battery which is best way to recharge do I leave on car an use the two front connectors or do I disconnect and take off car to charge. Does the bonnet go any higher for access? Crying or Very sad Range rover hse
Java black
Post #66102 28th May 2011 8:32am
invest in a new battery ready for the winter. yes the bonnet does go up to vertical for access..
Post #66106 28th May 2011 10:03am
993porky
Cheers scarey,the battery is only 4 weeks old put on before I bought car got receipt for battery included in paperwork for car when I bought 10 days ago, more probs since I charged and replaced battery thedrivers door only opens with key in lock and not key buttons like rest of doors and none of the mirror or window switches are working on drivers door now, gutted Big Cry Range rover hse
Java black
Post #66131 28th May 2011 12:22pm
dan_uk_1984
Charge it on the car, but disconnect the negative lead from the battery. This will hopefully reset your other issues too.
RR's can eat batteries, is the one that's on there a, genuine and b, the correct rating?
Post #66132 28th May 2011 12:41pm
993porky
cheers dan did dis connect and sure enough it did reset all working now im very happy now thanks Thumbs Up Range rover hse
Java black
Post #66198 29th May 2011 12:32am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Dan
my local dealer says that disconnection of the negative should make no difference....
is there any particular feature you are disabling by disconnection of the negative?
Post #68671 15th Jun 2011 4:46pm
dan_uk_1984
Rambles wrote:
Dan
No difference to what? No difference to your issues, or no difference whilst charging?
Disconnecting the battery is the widely accepted first method to fix any RR electrical issue...
One always disconnects the negative lead on a battery first - it's just how its done. When charging you don't want to stick the charging current into the car electrics - so by disconnecting the battery you break the circuit. Coupled with the fact the pyrotechnic charge lives in the positive lead and its generally a good plan to leave that alone!
Dan
Post #68684 15th Jun 2011 7:35pm
Rambles
just asking what difference taking the negative off makes. On all other vehicles that I have owned, I have fitted charging leads to the battery so when I want to recharge the battery, I simply plug the charger in.
Post #68729 16th Jun 2011 7:10am
with the amount of temperamental electronics on the range rover, i would take off both leads to be safe...
Post #68731 16th Jun 2011 7:11am
stu
a couple of questions please guys
how do you get the bonnet to go higher? do you have to take the gas struts off?
when disconnecting the battery, i read about the pyro blow you up thing in the user hadbook, but can you safely take the pos and neg leads off like you would with any other car? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #68735 16th Jun 2011 7:47am
you can get the bonnet into service mode by removing the two gas struts and using the two metal clips to steady the bonnet in a vertical position.
leave the range for 10 minutes with the key out of the ignition before you dis-connect the battery .
Post #68737 16th Jun 2011 7:51am
dan_uk_1984
There is no benefit to taking the pos lead off if you've taken the negative lead off as there will no longer be a circuit... All it means is you have to undo another connection unnecessarily and they are fiddly at the best of times. Whereas you can easily remove the negative lead with the bonnet in the normal position.
As per Scary - you don't want to introduce a surge through the vehicles electronics. Pretty much every car made today says in its handbook that you should not charge the battery whilst it's connected to the vehicle.
Personally I have charged the battery on the car, but only with a small 6A charger. Using any of the fast charge systems would be asking for trouble.
Now I have my second battery installed I no longer need to worry about this :p
Post #68748 16th Jun 2011 8:50am
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
[quote="dan_uk_1984"]
Rambles wrote:
One always disconnects the negative lead on a battery first - it's just how its done. Dan
It's always done for safety ! If you undo the positive first & accidentally hit any metal part of the car (or any other part that is connected to negative/earth) with your spanner it'll make a connection & you'll feel it !
Obviously if the battery is completely flat, then the risk is less, but on a fully charged battery you'll be amazed at the current flow you can get and sparks will fly. If you happen to be wearing a watch or ring and that bridges your spanner/positive connection to earth/negative on the car body, you will get a very nasty burn !
+ of course any sparking can case fires.
So this is the reason you should always remove the earth first.
There are rare occasions when you can come acrosss positive earths on vehicles - but they are rare and I think all vehicles after the 1970's were made with negative earths as that standard was introduced, but it's always good to check.
Post #68763 16th Jun 2011 11:51am
stu
thanks guys always good to get info from people who know!!.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #68829 16th Jun 2011 6:04pm
Rambles
Rolo
not sure how you did the cut and paste to say Rambles wrote "One always disconnects....".
But no I didn't.
Post #68916 17th Jun 2011 7:16am
