Home > Maintenance & Mods (L322) > Alignment / Tyre Wear
JDRR
Hi All,
First time poster here, just picked up my first L322.
I was going to get it aligned as the Front Left tyre has a lot of wear on the outer edge, however;
Is this normally linked to incorrect alignment on these cars, or is it more a sign of a worn bush somewhere? I'm assuming the alignment doesn't easily get knocked out given the abuse these can take off road?
Do these need someone who's well versed in FFRR's to align them? Or does any Tyre shop with a Hunter suffice? Didn't know if there was a service mode the air suspension needs setting to etc...
Thanks in advance,
Post #661034 4th Apr 2023 2:38pm
Weegie
Garage with Hunter system for four wheel alignment. Should be set in tight tolerance mode. Check with them that they do it.
Using Gap iid tool I set it myself to be sure John
GAP iiD BT-Sold
Post #661035 4th Apr 2023 3:01pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Weegie, That's interesting, Didn't know that you could put it into tight mode through the iid tool. Is easy to set up?.
Post #661036 4th Apr 2023 3:04pm
Weegie
Straightforward. Have to access the menu but IIRC through the suspension setup. John
GAP iiD BT-Sold
Post #661038 4th Apr 2023 3:07pm
Merchy
Before you take action, as it is a front tyre and you only mention one side wearing, has the car had a new steering arm joint or any recent work on the front end? It could just be a simple case of the tracking being out, which can be rectified at most good garages. Just a thought, could save uou a few pennies Thumbs Up
Post #661039 4th Apr 2023 3:12pm
JDRR
Thanks Weegie,
I notice you are in E.Sussex same as me, is there anywhere in particular local you'd recommend for maintenance/ service?
Locals I'm aware of, but have no experience with:
Thatched Garage
RCV
Pilbeam Bob
Post #661040 4th Apr 2023 3:13pm
Weegie
You have PM John
GAP iiD BT-Sold
Post #661042 4th Apr 2023 3:24pm
Highroller
Thanks, I'll scroll through the menu.Thumbs Up
Post #661044 4th Apr 2023 3:33pm
Gremlin500
I went to Tyre Spot in Durham today and got a 4-wheel alignment check on my L405.
They said it would be £90 over the phone, but when I got there, they got the car set up straight away and despite having new front lower arms fitted, all parameters were within tolerance so they said “no charge, sir!” Very friendly staff, and spacious waiting room with TV, plus, you can actually see them logging your vehicle into the system on another screen in the waiting area, and going through the procedure step-by-step, so you know its been done properly, great stuff! Thumbs Up Very impressed. V6 Vogue - “Less is More” - less to go wrong!
Post #666850 17th Jun 2023 3:56pm
JayGee
Wear on a single tyre would suggest more than a simple toe adjustment. Worn bushes, joints, shock absorbers etc should all be investigated. 2012 TDV8 Vogue (L322)
Post #666894 18th Jun 2023 9:04am
