![]() | Home > My Range Rover > First RR, First Post - Start of a journey to 200k hopefully! |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
4.4 TDV8s are pretty hardy beasts.
Hanwellfields Member Since: 22 Dec 2022 Location: Oxfordshire/ Cotswold Posts: 89 ![]() ![]() ![]() |
Welcome! And congrats on the purchase.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Welcome! |
w0lf4y Member Since: 29 Oct 2022 Location: Hertfordshire Posts: 4 ![]() ![]() ![]() |
I hadn't realised that I needed to disengage the parking brake before altering the ride height - thanks for the tip!
Thanks
Thanks Rob
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
[/quote] I've had the same error code for the last 2 years, and the doors still work fine. I've tried clearing the code, but it always returns... 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
I get the door lock errors too. Never been an issue either |
If you're on Facebook then you can find me on there too (Rob Holland) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
I'm with Dr Rob... don't let them butcher your fatty...
I'd not leave my driveway without the GAP IID Bluetooth in the car |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 994 ![]() ![]() ![]() |
Hi gary, I have the fault on my IID B1108-15 Parking Brake I may have accidentally put the electronic parking brake on and then changed the suspension height to "Access Mode" , could you tell me more about the un-jam procedure on the IID tool, I would like to try that and see if fault B1108-15 goes away, many thanks Peter |
