Home > Technical (L405) > Windscreen chip
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Windscreen chip
Picked up this chip the other day. On the Autoglass website it says less than 3cm, do nothing. It is in the middle of the screen, but way down the bottom. What do you think ? 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #661064 4th Apr 2023 6:33pm
Kot
A chip can cause a crack at any time get it sorted tomorrow, its an invisible repair.
By Autoglass etc
I have used Halfords repair kit with great success but that was on a 2mm chip. 2018 SE SDV8 4.4 Byron Blue
Post #661065 4th Apr 2023 6:39pm
your heated screen element might be damaged if he chip is a big one.. ... - .- -.
Post #661066 4th Apr 2023 6:44pm
GrandadRob
2.5 cm 2013 SDV8 4.4 SE Luxor.
Post #661067 4th Apr 2023 6:47pm
Kot
Quote from a repair company
When determining the size of a windscreen chip, here are the three golden rules:
If a chip is less than 3mm wide, there is no urgency to get it repaired.
Most chips smaller than a £2 coin can be repaired.
Any chips over 25mm are usually unable to be repaired and will result in your windscreen being replaced instead.
To fix a small chip in the windscreen will cost around £40 to £50 in the UK, although if you need the windscreen completely replaced, you’ll be looking at a price of between £200 to £250.
Post #661068 4th Apr 2023 7:14pm
knwatkins
I had a similar one last year. Rang autoglass, they sorted it with the insurance company. Excellent job, couldnt even see it after the repair. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #661156 5th Apr 2023 10:16pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I had similar and just popped it to Halfords. The repair took about 15 minutes and was invisible.
Post #661164 6th Apr 2023 8:19am
caymanblack
I agree with Kot, repair it asap. overfinch modified
Post #661170 6th Apr 2023 9:38am
Gremlin500
#3
Get it sorted asap, the crack is included in the size of the “chip” so that’s quite a big one, and could even be borderline unrepairable. Also cracks can “grow” with heating/cooling and vibration.
I’d do it immediately. V6 Vogue - “Less is More” - less to go wrong!
Post #661205 6th Apr 2023 2:03pm
