Home > Maintenance & Mods (L322) > Do I just hit it with a bigger hammer?
Vogue
tap it out with a big hammer - some owners jamm a sliver of wood in the socket to stop rattles - thats why some are seized in. I shove a business card between the receiver and square section to stop the rattle. If you have experienced the rattkle you will know what I mean, it drives you slowly insane especially with a twin axle trailer due to axle tramp
Post #66005 27th May 2011 11:40am
supershuttle
Censored still won't budge, I've left it soaking up some more WD 40 will try again next week. Got to go get beer for football tonight Thumbs Up Geoff
Post #66134 28th May 2011 12:46pm
stu
if it is this tight, heat may be your only option. when you do get it out i would suggest you don't leave it on again, without wanting to state the obvious. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66139 28th May 2011 2:37pm
supershuttle
I don't tow stuff so will be happy to get it off and keep it off unless I have my bike rack on (home made - bolts to the plate) as the drop plate reduces the ground clearance at the back and doesn't look all that good either. Censored thing! Geoff
Post #66152 28th May 2011 5:36pm
I spent yesterday removing the rear bumper anfd towbar and trying to remove the farmers hitch but without success. Today I took the assembly to my local garage where they placed it on a 20 tonne hydraulic press and applied heat with an oxyacetylene torch, it took almost 90 minutes of heating and pressing before the hitch eventually gave and came out of the slot. It's obviously never been off since the day it was fitted and now won't be going on unless I need to tow the trailer.
Post #67436 7th Jun 2011 2:36pm
supershuttle
Groan Crying or Very sad Geoff
Post #67437 7th Jun 2011 2:38pm
Looks like you might have the same problem as me Big Cry
Post #67438 7th Jun 2011 2:39pm
