![]() | Home > Technical (L322) > Upper boot hatch slipping down on one side? |
| oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397
i would say the bolts have come loose check which ones might give you some idea to adjust new vehicle purchase
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
1/2” where? At the top or at the bottom edge when it’s raised?
| lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 63
When closed it is about half an inch lower on the right hand side....I have found the Powerful UK video for the newer model but the L322 is completely different. I can only see one bolt in each of the top corners and that seems completely rigid with no scope to adjust it. I will post a photo this evening |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965
If it’s the plastic spoiler that’s not even with the roof line across both sides, it may not be properly clipped into all three retaining ‘lugs’. If you loosen / remove the three 10mm bolts from the underside, you should be able to tell if it’s been fitted correctly. Jonathan
| All times are GMT |
