Home > Maintenance & Mods (L405) > A rust trap on your L405 you probably aren't aware of....
Gremlin500
Go grab a torch.
Open both tailgates, and lift the little carpet flap thingy up from the lower tailgate, -handy if you have something to keep it up out of the way. (I used to have 2 rusty bolts in there until I replaced them with painted ones, but that's not what I'm talking about)
Switch the torch on, and take a look inside the square hole on the left (passenger) side of the car.
You will see a perforated steel grille in there, -not sure what it does, but it's probably rusty!
Thanks JLR, something else to worry about..... V6 Vogue - “Less is More” - less to go wrong!
Post #661445 9th Apr 2023 7:15pm
It's a plastic tailgate so they had to put some ferrous metal in there somewhere, and of course, leave it untreated.... Rolling Eyes Rolling Eyes Pete
Post #661447 9th Apr 2023 7:29pm
TJH1985
It’s ok the sunroof drains will have totalled the car way before that causes a concern Rolling with laughter Whistle
Thanks for the heads up, another thing to obsessively check Mr. Green Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #661451 9th Apr 2023 9:37pm
Gremlin500
Thank God I have a “poverty spec” car, without roof drains or Dynamic Response corrosion to worry about, although my crankshaft is forged from high-density carotene, of course (yawn) Rolling Eyes
Said perforated steel bit isn’t in the lower tailgate itself, it’s in the bodyshell in front of the rear bumper, probs something to do with HVAC? I haven’t a clue, but my MY2017 has light surface rust in there already, and being perforated metal with a large surface area to volume ratio, older vehicles could be badly affected. I’ve sprayed some ACF50 in there for now. Crying or Very sad V6 Vogue - “Less is More” - less to go wrong!
Post #661453 9th Apr 2023 11:14pm
Thanks for the heads up gremlin... Ill have a look at ours tomorrow Thumbs Up
Post #661457 10th Apr 2023 1:45am
caymanblack
Yes, thanks Gremlin will check mine also. overfinch modified
Post #661476 10th Apr 2023 11:09am
AnotherMutley
May be not a rust trap, but if you want even more paranoia, pull out your front inner wing liners and check out the amount of leafs and stuff in there.
Post #661484 10th Apr 2023 12:32pm
Gremlin500
Bow down
Oooooh, I love a bit of FFRR paranoia! The great thing with us paranoia-obsessed types is there is always something else to worry about you weren’t aware of, they just keep giving! Laughing
Out with family today so that one will have to wait Shocked Laughing
I have a vision of lots of FFRR owners up & down the country, trying to remember “now, where did I put that bl**dy torch?” Rolling with laughter Rolling with laughter Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #661488 10th Apr 2023 1:11pm
Just went to look at mine and found this....
https://www.fullfatrr.com/forum/topic66566.html
So check that as well.... Shocked Pete
Post #661489 10th Apr 2023 1:11pm
TJH1985
Anyone got a picture? I couldn’t quite work out where I am suppose to be checking Embarassed Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #661522 10th Apr 2023 6:15pm
knwatkins
Same here. I've just been out to mine to check. I can't see any rectangular holes back into the body :-s
I have two galvanised bolts, each have a few spots of surface rust on them but by no means require replacement. Maybe a spray with some protection or a quick paint with some touch up paint to keep them looking good.
Can you take some pics of the place you are talking about Gremlin? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #661525 10th Apr 2023 6:27pm
caymanblack
Gremlin , a picture would be good. Poor Kev has spent the whole of easter Monday looking for this rust trap Rolling with laughter overfinch modified
Post #661530 10th Apr 2023 7:04pm
AnotherMutley
Gremlin500 wrote:
Bow down
Its been mentioned before, there's nothing really to stop (unless you park your car in a garage and only take it out in summer) leaves from near the bonnet hinge from dropping down inside the wing in the void between the wing and the body, the foam doesn't really do much.
Post #661531 10th Apr 2023 7:23pm
knwatkins
I have indeed Rolling with laughter Thumbs Up Kev
Post #661553 10th Apr 2023 10:21pm
Gremlin500
Ah, sorry guys, I’ll try to take a picture, but big day tomorrow its the annual 4K service!
The hole is about 50mm square, and is readily visible on my MY 2017 model, the mesh is on a bulkhead maybe 60-70mm behind that, you will not see it without a strong torch in daylight, its pitch black in there! V6 Vogue - “Less is More” - less to go wrong!
Post #661555 10th Apr 2023 10:31pm
