Home > Maintenance & Mods (L405) > What typically gets done at a 200,000km service? (SCV8)
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I looked on the wiki but couldn't find a 200,000km service checklist.
Also happy to receive any "above and beyond" service recommendations.
Thanks
Post #661502 10th Apr 2023 3:19pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
A bottle of champagne Thumbs Up
Post #661503 10th Apr 2023 3:36pm
Put your VIN in here, that will tell you... Thumbs Up
https://osh.landrover.com/ Pete
Post #661504 10th Apr 2023 3:38pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
It depends on what services you have already completed. Here are some items that could be on the list:
Replace spark plugs
Replace spark plug bolts
Inspect and replace drive belts
Check left timing chain through oil fill hole
Transmission service
Front and rear Differential service
Replace brake fluid
Replace power steering fluid
Replace ACE fluid
Engine oil
Air filters
Cabin filter
Inspect and replace brake hoses
Replace coolant
Inspect and replace water pump
Inspect and replace coolant crossover pipe
Inspect and replace vacuum pump
Lubricant chassis and sunroof
Clear sunroof drains
There will be a Land Rover service schedule. Unlikely it is as detailed as above. YMMV. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #661516 10th Apr 2023 5:22pm
Salsbury
Thanks team. Much appreciated.
Post #661558 11th Apr 2023 3:57am
Salsbury
I gave up the bottle a few months ago so some Ginger Beer will have to suffice!
Post #661559 11th Apr 2023 3:58am
knwatkins
There is no power steering fluid. It's an electronic system, not hydraulic. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #661561 11th Apr 2023 7:20am
Bora20
Thanks. I meant blinker fluid 😉 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #661602 11th Apr 2023 3:34pm
