![]() | Home > Maintenance & Mods (L322) > Overheating 4.4 TDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
My top hose used to collapse and needed to be replaced. I also changed the expansion tank cap. Mine didn't over heat though. Caps are only a fiver. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
The heater on max, and fans full dropping the temperature suggests that the system is able to dump heat through the heater matrix, but that its not doing that through the main radiator where it should be dumping the most of the heat in a normal manner.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2724 ![]() ![]() |
I would be changing the thermostat without further delay. |
Be aware that there has been a parts shortage of thermostat housing parts for a while so check you can get the part before you remove it. The thermostat housing is part of a bigger component and can’t be purchased separately however it can be replaced without removing the whole housing which makes it an easier job but still requires quite a bit of work removing fan and belts etc. I wouldn’t drive it in this condition either. 2012 TDV8 Vogue (L322) |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Many thanks to all for the advice...
I'm another who didn't think to change the thermostat when changing the pulleys and belts. I did change the water pump though. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 377 ![]() ![]() ![]() |
I would check belt tensions as well to ensure water pump is being driven ok. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
THank you for the advice...
Broadley RR Member Since: 13 Oct 2022 Location: East Kent Posts: 1 ![]() ![]() |
Hi,
I changed the thermostat. The issue was the thermostat sticking closed. I had ordered a complete thermostat replacement from Duckworths, but these parts were on back order with no anticipated delivery date.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 188 ![]() ![]() ![]() |
running without thermostat will overheat engine! You need blanking plate, to close short circuit. |
My leaking thermostat
No will not. Even damaged yhermostat if opens to radiator will restrict flow in short circuit. If you remove then water will flow where lower restriction is,so will go mostly back to the engin rather than long way through radiator. |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 ![]() ![]() ![]() |
Jsut a quick thread revival here,
