![]() | Home > Technical (L322) > Traction control kicking in inappropriately |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1414 ![]() ![]() |
Started happening to me, then the airbag failed completely on that side, check you don't have a leak on that suspension spring. |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
It looks level on all corners. I will measure the wheel arch gaps overnight and see if there is any great distance |
Mine was level and not losing air at normal ride height, suggest you raise to highest and lowest setting a few times and listen for the leak. Turn wheels to simulate turning a corner... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
A worn outer CV joint can give a judder/ grabbing sensation in a turn which is a bit like ABS kicking in 2012 TDV8 Vogue (L322) |
