Home > Maintenance & Mods (L322) > Door upper finisher B
Sandyt
Gents mine are getting quite badly corroded - I am assuming that they are just alloy covers but cant find any on the net anyone know if they are paintable ie take them off rub down and paint? or where to get them
Post #662140 17th Apr 2023 7:44pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
I'm guessing this is what you're referring to ?
Sadly, I don't think it's fixable - at least not easily or cost effectively.
The blemish shown here was present on my FF when I bought it five years ago.
Fortunately for me, it does not appear to have worsened in that time.
I think it's quite common.
When looking for my current car, I did see at least one other similarly afflicted.
I did sound out my Indy with a view to addressing about a year later.
I forget the detail of his response, but what it seemed to amount to was I think pretty much a dismantling of much of the door.
I think I recall him saying that the satin finish coating is not a self-adhesive film.
Sorry.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #662270 19th Apr 2023 1:20pm
Sandyt
That is indeed the offending piece I haver corrosion on both front doors not sure if it is paintable - Mine is going in to have sills and wheel arches done in a couple of weeks also doing pretty much a full respray - 200 odd thousand miles of chips etc so will ask them to have a go.
Interestingly they are not to be seen on eBay
Guess it might be one of those bits that I just dont look at Laughing
Post #662271 19th Apr 2023 2:07pm
dhallworth
I swapped both of mine when doing the work on the car. Funnily enough the corrosion on mine were only on the front doors too.
They're available from LR and are around £50 each.
Part numbers are:
RH Front Door - DDC000121PMD
LH Front Door - DDC000131PMD
Easy enough to change... Open the window, gently prise out the rubber and unscrew.
Post #662274 19th Apr 2023 3:14pm
Oh really ?
It would appear that I have been misinformed.
Thank you for the information.
Post #662278 19th Apr 2023 3:56pm
dhallworth
Here's the link to part numbers and prices:
https://parts.jaguarlandroverclassic.com/p...and-rover/
They're showing in stock so you can order direct from that link or from your dealer. Often worth searching eBay for dealers selling off new old stock slightly cheaper too.
They are very simple to change, details of how are on the forum or in the workshop manual on the Wiki Smile
Post #662279 19th Apr 2023 3:59pm
Marvellous.
Thank you David. 2011 L322 TDV8 A/b Orkney Grey
Post #662282 19th Apr 2023 4:16pm
Sandyt
David I should have known you had done this Wink you have done everything else thank you for the info and hope all is well at home Thumbs Up Thumbs Up
Post #662283 19th Apr 2023 4:22pm
