Home > Maintenance & Mods (L322) > Transfer Box Fluid
kevinp
Post #555019 23rd May 2020 3:49pm
kevinp
So, I just done all my fluids. When I took the engine under tray off it was full of oil and gunge. The front right drive shaft seal has gone hence why only half the amount of oil drained from the diff. Private Indy has quoted £222.60 for the repair under a separate warranty I had when I bought the car. If you do your oils it might be worth a check for any leaks. Cheers Kev.
Post #555984 31st May 2020 11:04am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
RRPhil wrote:
Just to be sure that there’s no confusion here.
If you have a 5-speed transmission (ZF 5HP24 or GM 5L40-E) you have the New Venture Gear NV225 transfer box.
If you have a 6- or 8-speed transmission (ZF 6HP26/28 or ZF 8HP70) you have the Magna Steyr DD295 transfer box.
The two transfer boxes require different fluids.
For the earlier unit (NV225) the fluid friction characteristics have to satisfy the requirements of the Torsen Type-B centre differential and the range-change synchroniser cones – hence you should only use Castrol BOT 26 FMB 1 75W-90 (1 litre capacity).
For the later transfer box (DD295) the friction modifiers in the fluid have to match the requirements of the multi-plate clutch, which performs the front-to-rear torque biasing & centre diff. lock, and the range-change synchroniser cones – hence you should only use Shell TF 0753 (1.5 litre capacity).
Phil
Reviving this thread to see if things have moved on in the last few years; I’m having trouble finding Shell TF 0753. But I can see that Smith & Allan specifically state conformance to Land Rover IYK 500010LRN 0753TF 0753. To quote from their spec:
Quote:
Transfer Fluid 0753 is intended for use in Jaguar / Land rover vehicles which incorporate electronically controlled active transfer cases, where the fluid TF 0753 is recommended for use by the original equipment manufacturer
Here’s the link https://www.smithandallan.com/product/smit...fluid-4187
@RRPhil was very specific on use of Shell TF 0753 so what’s people’s experience today? Anyone used the Smith & Allan branded equivalent oil ? TDV8 4.4 2012
Post #662415 20th Apr 2023 11:06pm
GraemeS
Australia
I've been using Ravenol TF0870 for the last 70,000 kms without any noticible change from the LR oil.
Post #662418 21st Apr 2023 1:08am
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
I’ve used Smith & Allen oils with no known issues. Totally understand the apprehension regards getting correct spec. I believe Smith & Allen have an association with Shell. I used their “ TF 0753 “ in my t/fer box, diff oils, & their 5w30 C1 engine oil.
Post #662419 21st Apr 2023 5:29am
knwatkins
I also use S&A transfer fluid. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #662424 21st Apr 2023 8:22am
Ramblin Man
Thanks all, that’s good to hear. I’m going with the S&A oil. TDV8 4.4 2012
Post #662428 21st Apr 2023 9:26am
Superspoons
I've used Smith and Allan oils on my Diff's/Transfer and Engine - all in spec and no issues. Give them a call - really helpful people.
I've documented it all here - https://www.fullfatrr.com/forum/topic63354.html
HTH Gavin
https://www.youtube.com/@ChallengingClassics
Post #662430 21st Apr 2023 10:05am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Likewise, S&A fluids throughout my 2012. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #662431 21st Apr 2023 10:10am
