Home > Technical (L405) > Start/Stop button replacement
funnyguy1
United States
Question, I ordered a new start stop button for my 2016. I have seen youtube videos where you can just pry it out of it fitting on dash and replace. Other videos show the entire leather surround coming out and then the instrument cluster trim piece coming out. Has anyone replaced theirs?? hoping its the former. Thx!
Post #662825 25th Apr 2023 10:36pm
I changed mine, no tools needed, pull off the head unit surround which also has the part below the start/stop button, just get your fingers under the edge and pull it off. Then stick your finger up underneath the start/stop switch and pop it out towards you... Unplug it and swap it for the new one. Takes about a minute.... Thumbs Up Pete
Post #662829 26th Apr 2023 7:24am
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I found removing the 2 screws around the speedo and partially removing that helped with removal. There is one bottom left and another at the top above the clear plastic section thats under a plastic cover
Post #662851 26th Apr 2023 11:42am
funnyguy1
United States
Thanks guys! I was ready to pull out the instrument surround with the chrome trim. This sounds much easier! Mike
Post #662865 26th Apr 2023 3:41pm
knwatkins
I replaced mine a couple of years ago. I can't remember how exactly, but I know I didn't remove the instrument cluster. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #662889 26th Apr 2023 9:37pm
funnyguy1
United States
I got the switch out thru the front but had to virtually break all the tabs on it, then the new one popped right in. Probably not a recommended replacement procedure but I dod not want to take the instrument cluster out.
Post #662891 26th Apr 2023 11:03pm
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi, I replaced my broken button as it had bits missing out of the middle. You can replace the whole unit but you can have issues with the car not recognising the new switch as it has a PCB inside that the car reads not always an issue but still. The unit is held in with 3 clips on a L322 and just levers out around the edges (protect the soft leather on the dash with a cloth under your lever so as not to damage it). You can buy the actual replacement button for less than £5 off eBay, as opposed to the whole switch for £20. I did a few photos of stripping it down if anyone is interested. Re-assembly is just a case of popping in the button and opposite of above. 2011 4.4 TDV8 Autobiography Ipanema sand
2007 3.6 TDV8 RRS HSE Black
2003 4.6is V8 BMW X5 Black
2000 2.5 TD5 Discovery Blue
2000 1.8 Freelander Black
Post #662945 27th Apr 2023 4:47pm
Yellopin
Oops, forgot to press add photos! Doh!
Post #662946 27th Apr 2023 4:48pm
OP is talking about a 405 which is different to the 322
As I said above, you can change the button WITHOUT removing the dash, just pull off the head unit surround which is one piece with the trim under the button...
Put your finger in at the bottom of the trim around the button, hook your finger and push the button out towards you...
No tools, no damage, no risk of damage and takes about a minute...!!!!!! Pete
Post #662965 27th Apr 2023 8:16pm
Yellopin
My apologies, must read the f…… question before speaking out. 2011 4.4 TDV8 Autobiography Ipanema sand
Post #662966 27th Apr 2023 8:27pm
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
I removed the head unit trim and put my finger behind the start/stop button to push it out but it will not budge! Any tips so I don't have to remove the instrument cluster surround..? 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #684604 2nd Feb 2024 11:20am
Ryanmt
Just remove it. Its dead easy Thumbs Up
Post #684605 2nd Feb 2024 11:21am
Jase71
the instrument trim? Just trying not to mark anything..will drive me nuts looking at it otherwise 2017 Range Rover Vogue V6 Diesel
Post #684606 2nd Feb 2024 11:40am
Ryanmt
Yep just the black plastic bit. Only a couple of torx
Post #684608 2nd Feb 2024 12:08pm
Jase71
All done. I didn't like removing the instrument surround at all but until I removed the button holder there was no way I could remove the switch. So definitely not a quick job but I guess every car is different. Just a sharp intake of breath required a you do the disassembly and hope it all clicks back together! Not hard work at all just a high potential to damage trim and attachments! 2017 Range Rover Vogue V6 Diesel
Post #684622 2nd Feb 2024 3:20pm
