![]() | Home > Maintenance & Mods (L405) > Dynamic Mode |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Anybody bought the Dynamic Mode update from here...
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
If installed / upgraded, how would you be able select dynamic mode when its not listed as an option on the terrain response dial physically?
You buy a terrain knob from a Sport which has Dynamic mode, it has an extra setting..... Pete
Apparently if you buy the switch you can just enable Dynamic mode in the CCF... I haven't looked yet though... |
hmmm interesting.
This is the standard one...
I dont drive mine fast enough to think it'd be worth it. .... had it on the evoque and didn't notice that it made that much of a difference under spirited driving. Plus, I hated how the evoque cluster turned red ... as per the advert for the L405 does as well.
| Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802
I’ve got dynamic mode on mine and use it when I want the anti-roll to kick in straight away (plus roll is helped by the suspension being slightly firmer), which is doesn’t when terrain response is in auto. MY23 Panamera E-Hybrid
Cheers, do you notice any other difference...? Pete
| Max94L405 Member Since: 27 Jan 2023 Location: Hampshire Posts: 41
I’ve found the traction control to kick in more often when cornering which it wouldn’t do in auto/ normal mode. |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367
I can tell the difference on the Mrs's evoque. I do find the red dash irritating though.
