Home > Maintenance & Mods (L322) > Egr blanking kit for 4.4 tdv8
Craig5
hi everyone just bought a 2011 autobiography and saw lots of threads regarding the egr best being removed or blanked but I can’t seem to find the kit to buy as only ever seems to be kits for the 3.6 are they the same? And in same location?
Post #663524 5th May 2023 5:04pm
Dolphinboy
think you'll find that the 4.4 is best left well alone. EGR blanking will interfere with the engine settings/CPU and b*gger up your DPF regens (so I understand).
The 3.6 DID benefit from the EGR blank.
Post #663526 5th May 2023 5:16pm
Craig5
so are they easy to remove and clean?
Post #663528 5th May 2023 5:28pm
mjdronfield
Yes, the posts about issues and best removed or blanked generally relate to the 3.6. As above, best left alone on the 4.4 as affects things more.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #663529 5th May 2023 5:29pm
Craig5
so best to clean?
Post #663530 5th May 2023 5:38pm
mjdronfield
Yeah, they can still get gunged up. Not sure if there is a how to in the Wiki.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #663533 5th May 2023 6:03pm
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Not long ago I had a Quantum tuning remap including mapping out the EGR.
I then made a 2mm stainless blanking plate to physically block off the EGR.
My MPG has increased from 24mpg to 27mpg avg. I rarely do motorway miles and boot it past 3k rpm every journey at least once to wake the second turbo up. I'm fairly pleased!
Drivability and torque has definitely improved...just wish I could find a solution to mapping the ZF8 box!
Post #663543 5th May 2023 9:28pm
GraemeS
Australia
I'll make my own plate when I get around to it, having had a very mild remap with EGR delete some time ago.
For those with a DPF who are concerned about the effect on re-gens, the EGR valve gets CLOSED during re-gens to ensure that the fuel-rich exhaust all goes to the catalytic converter so that it can produce the required heat to burn the soot in the DPF.
I consider that the EGR cooler is probably responsible for the demise of the oil cooler gaskets so preventing EGR should increase the life of those gaskets.
Post #663545 5th May 2023 9:51pm
hotpotatojr
Yes to add, in the spirit of transparency (if those read my other recent posts) I've had DPF full issues recently but they have been unrelated to EGR blanking and since resolved. So don't let that put you off.
I'm currently floating around 3-4g soot and it regens passively quite nicely.
Post #663546 5th May 2023 9:55pm
JayGee
Re: Egr blanking kit for 4.4 tdv8
Most people have no issues with the EGR valve on these engines and see no reason to disable it. 2012 TDV8 Vogue (L322)
Post #663561 6th May 2023 11:03am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
4,4 EGR is quite eternal part, almost never fault. There is nothing to clean, it just black inside like exhaust pipe, and you dont clean exhaust pipe, right?
Leave it alone.
Post #663571 6th May 2023 3:58pm
PeteT80
If it ain’t broke, don’t fix it.
Post #663575 6th May 2023 4:33pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
In the interest of providing a balanced set of replies here, you can indeed remove/blank the EGR system. You just won't find a kit to do it so need to make your own. 2mm steel plate is fine.
Here is a more in-depth discussion with both sides of the argument laid out https://www.fullfatrr.com/forum/post644387.html#644387 Cam
2011 TDV8 Vogue in Stornoway Grey
Post #665013 25th May 2023 12:24pm
JayGee
As it needs a remap to get it to run without EGR flow why go to the trouble to physically blank it as well? 2012 TDV8 Vogue (L322)
Post #665014 25th May 2023 12:47pm
telly-addict
Pretty sure this has been covered before, but if mapped out it is to cover the possibility of a sticky valve surreptitiously leaking. Cam
Post #665015 25th May 2023 1:07pm
