Home > Maintenance & Mods (L322) > Rear sub frame bushes
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hi
Does anyone know how long RAVE says it should take to change the rear sub frame bushes in a 2011 4.4 ?
Thanks
Post #663685 9th May 2023 5:34am
kevinp
I've got a set of Genuine bushes sitting on my shelf in the garage and I'm waiting to pluck up the courage to get them changed.
I'm thinking I could do them in a day as long as the bush extractor I've bought is man enough to pull them out.
Are you planning to do them yourself or have you had a horrendous labour quote?
Post #663686 9th May 2023 6:37am
Joe90 did an excellent write up here...
https://www.fullfatrr.com/forum/topic21092.html
It' looks like it took over two days to do them on his drive, and yes you need a decent puller, the cheap ones on ebay just don't work...!! Pete
-Click here for Thread-
Post #663689 9th May 2023 7:56am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
I bought the pulling kit of ebay and the correct bushes rather than the BMW ones, took me a day to change all four bushes, mine also had the rivets in that needed drilling out and replacing (2012 model)
Its a doable job for the DIY mechanic Thumbs Up
 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #663715 9th May 2023 5:26pm
I let me local Indy do mine Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #663742 10th May 2023 11:07am
Rambles
Alanm_3
How many hours labour is your indie asking?
Does 12 -14 sound about right ?
Is there an official by the book number of hours in RAVE ?
Thank you to others for responses
Post #663879 11th May 2023 5:24pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Can anyone recommend a bush pulling kit?
And, other than MOT advisories, what’s the symptoms of failing/failed rear subframe bushes?
Thanks 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #663887 11th May 2023 6:36pm
Hi Rambles, I don’t think it was anywhere near that but it was the top hub bushes that were replaced, I’ll look out the invoice and let you know Thumbs Up
They said initially that the bush had all but disintegrated and that the entire hub assembly might need to be replaced , as it had been moving around, possibly enlarging the hole but fortunately it was just the bush. Got - 2017 SDV8 Autobiography in Loire Blue
Post #663892 11th May 2023 7:19pm
Mikey
Hub bushes are definitely not subframe bushes Thumbs Up
Post #663898 11th May 2023 8:21pm
Mikey
Rambles wrote:
Alanm_3
Is there an official by the book number of hours in topix?
Book time is around 6 hours, from memory. On a brand new car. With the JLR tooling. You'd have to be pretty lucky to achieve that on a 10yr old L322 Laughing
Post #663899 11th May 2023 8:22pm
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I've just done mine - took me about 4h.
I used this tool:
https://www.amazon.co.uk/dp/B014JL7F9O?psc...ct_details
I'll be selling it on now I'll likely never use it again.
I used X5 Meyle bushes and 6mm rivets in the original holes.
Alternative is to use genuine LR bushes and sealant.
Post #664033 13th May 2023 8:13pm
Sandyt
Just about to do mine for the second time last time it was a full day might be easier this time Thumbs Up
Post #664124 14th May 2023 8:56pm
Sandyt
Post #664125 14th May 2023 8:56pm
