![]() | Home > Maintenance & Mods (L405) > L405 oil drips from rear end |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1560 ![]() ![]() |
It’ll have the active roll bars if it’s a 4.4.
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 96 ![]() ![]() ![]() |
Now that’s a great idea !
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
We had the rear diff pinion seal go on ours, dealer suggested it was common when they fitted the repair kit, worth checking also. MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Also thanks !
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
The active roll bar pipe replacement is many thousands of pounds at the dealer, I too have been looking at alternative pipes, the unit end is pretty straight forward but the other end may prove challenging... Hope it's a cheap fix for you... |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096 ![]() ![]() ![]() |
Rear diff pinion seal is a common issue. Had mine sorted under the AU warranty and no issues since. |
Was it a simple job mate ? |
Regarding the pipes, afaik, they are metal at each end to start off with, so not outwith the realms of possibility to use them to begin with and attach a new length of hose between.
So had it on ramp, it’s the prop pinion seal at the inlet to the rear diff that leaking.
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 155 ![]() ![]() ![]() |
There is a LR tool for the pinion oil seal or you can by aftermarket spanners like this:
Thanks for the reply !
The marking up is only to ensure you don't overtighten the bearing which would reduce the service life. It's only to return it to its original factory setting. Just think of it like setting the timing against some marks on the crank. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I had the front pipes for the ARC corrode at one of the clamps on the front offside chassis rail.
I’m intrigued?
