![]() | Home > Technical (L405) > Transmission concerns |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1563
Gearboxes learn and self adapt their bite points for the clutches, and will do so to deal with the oil as it changes over time and wears. So new oil will behave differently from the old oil, but the box it still set for old oil. You can generally reset a ZF box by:
| goddo Member Since: 27 Oct 2020 Location: south Posts: 84
Thanks for that advice. I shall give a go tomorrow.
| baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 156
It is recommended that the oil be changed at 50k miles so your box should be coming up for its second oil change and will be overdue if it has never had one. So, I'd get the oil changed before doing an adaptive reset as new oil may make an improvement int he box feel.
Thanks for the reply baz000000.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
There are a lot on here who do not reset adaptions, it is thought that this could do more harm than good and like telling the Range Rover it has a new battery, there is no reason to do it as it will learn that the gearbox and/or battery have changed in normal driving...
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Do you use the flappy paddles to change up/ down. These can sometimes cause the gearbox to reprogramme itself to reflect your driving style. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
V8bob,
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
The gearbox constantly self-adapts anyway, so over time it will adapt to the new fluid anyway. No harm in doing a reset though. Kev
| All times are GMT |
