![]() | Home > Maintenance & Mods (L405) > Retrofit Adaptive cruise turn off on pre 2017 models ? NO |
| lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 101
I guess from the lack of a response it is a no ! |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
try a forum search.. ... - .- -.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
I don't know of a way to do it.
You can't ! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
If you try to disable parts of the system I would imagine it would fault the whole cruise control feature so nothing worked... Pete
| rstoughy Member Since: 17 Dec 2022 Location: Stonehaven Posts: 27
I looked at this also.
this thread is for the L322 but might work on the L405,
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2774
The button holding procedure that someone with a L405 mentioned was to hold the distance reducing button for a few seconds after the minimum distance is shown which is only shown whilst ACC is enabled. I don't recall on which model L405 this worked though. I suspect ACC would be re-enabled on the next ignition cycle rather than permanently off, similar to the minimum distance resetting. |
Thanks gents - I'll give those a try.
Your radar unit must be more than just a little out of alignment. When I fitted my radar unit my eye-balling for staight ahead was good enough to prevent false alerts.
I agree with Graeme, mine doesn't do that, I use it all the time and never had it slam the brakes on...!! Pete
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
I assume the question is "Can I just have cruise control without the adaptive bit..?"
I'll have to have a look for the radar sensor. It doesn't do it often and I have sort of leant to drive around it now - taking it extra wide around trucks. I can't remember whether I've had it happen in the UK, so maybe it's something about driving on the wrong side..... |
Comports,
