Home > Technical (L405) > Faulty rear light help
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I realised tonight my left rear light is faulty. The reverse, stop and brake light turn on for a split second before going out. I had a good Google but no results really for the rear light failing. I have no warnings on the dash to indicate a fault.
I made a video using the bulb test feature for the towbar as it does the same thing. You can see the light flash as it alternates through
Any ideas?
Post #664300 16th May 2023 9:13pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Look at the earth generally lighting issues are caused by a faulty earth. This is especially so on trailers . 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #664318 17th May 2023 8:10am
Ryanmt
went low tech and swapped them round and the fault follows the light cluster.
Strange thing is its dated 2021 so its an OEM replacement and its still failed.
I wasn't looking for an excuse to upgrade to the 2018 rear lights but I guess I have one now!
Post #664347 17th May 2023 2:01pm
