|  | Home > Wheels & Tyres > Correct Storage of Spare wheel ! |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 214      |
|  21st May 2023 10:35am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | What size tyre is on said wheel sir? | ||
|  21st May 2023 10:40am |
| PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 238      | Mine is General Grabber AT3 255/55/20 and have to deflate the tyre to about 20 psi, quite a snug fit.
|  21st May 2023 10:51am |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 214      | 255/50/20 RR Westminster 2012 Standard fit | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | The L322 was not designed to run the larger L405 size tyres so it's a tight fit for a spare. 2012 TDV8 Vogue (L322) | ||
|  21st May 2023 11:25am |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | try and get a spare wheel lifting harness strap, or whatever they are called, just makes life a little easier in getting the   | ||
|  21st May 2023 10:01pm |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818    |
 Plus size for size a General Grabber AT is also a bit bigger than standard 255/55 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 | ||
|  22nd May 2023 5:24pm |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 214      | thank you all again for your replies.
|  22nd May 2023 9:47pm |
| Posting Rules
 out
  out
