Home > Technical (L322) > 2010-2012 o/s/f LED sidelights not working
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
A few days ago I noticed my drivers side front LED sidelamps were flickering a bit. Now they are not working at all. Headlamps (dipped/beam) are OK and all the other sidelights are fine.
There's nothing on the dash to say that there's an issue with bulbs or such like and no warning messages with a yellow triangle either (which surprised me)!
I've pulled the electrical plug at the back of the lamp unit, inspected it and pushed it back into place. Had a squint inside the lamp unit by removing the two round caps on the back, but didn't see anything untoward there either.
Can anyone offer any wisdom here? Is there a fuse just for the right sidelights? Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #664695 22nd May 2023 2:47pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Ya reckon there’s a small possibility that it may just be the bulb
Maybe swap it for the other side just to rule it out? 2016 4.4 diesel
Post #664731 22nd May 2023 9:54pm
I think you will find they are non serviceable LED's you have to change the whole light unit... Shocked
I expect you could take it apart somehow and find a similar LED to go in there but not a straightforward job.... Pete
-Click here for Thread-
Post #664741 22nd May 2023 10:49pm
JMC
Well that's not happening....... Whistle Big Cry The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #664759 23rd May 2023 9:04am
unusual for these led lights to fail...i would double check the connectors and the wiring around the light unit.. ... - .- -.
Post #664765 23rd May 2023 9:44am
JMC
Was told today that sidelights are part of the MoT, so this is now becoming a priority. Can't believe I'm the only person to have suffered an LED failure in the last decade. It's not just one of the LED's, it's all of them in the headlamp unit. Also find it odd that, with all the electronic gizmo's in the late L322's, there's nothing on the display to say there's a bulb failure. Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #664960 24th May 2023 9:35pm
I take it you have tried the usual fuses... there can be more than one in a system... Pete
Post #664965 24th May 2023 10:30pm
JMC
Yes, fuses are fine. Thumbs Up
Just to clarify what's not working - it's all the white LED sidelights. The orange LED indicator lamps are fine.
Been doing some digging on-line and there appears to be an LED control module on the back of the headlamp assembly. Perhaps it's time to investigate this unit..... The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #664976 25th May 2023 6:38am
Good luck... Thumbs Up Pete
Post #664978 25th May 2023 7:19am
JMC
The plot thickens.....
I dismantled the front a bit earlier today and with a 'slight modification' to the headlamps, I finally managed to remove them and swap them over to see if the fault was intrinsic to the lamp unit. (It appears that the front bumper needs to be removed to get at the fourth mounting bolt. I didn't do that..... Whistle )
It's not the headlamp unit at fault! Big Cry
The 'faulty' unit was plugged into the passenger side and the sidelights worked perfectly. The good unit was plugged into the drivers side and the sidelights didn't work.
@Haylands - the fuses for the sidelights are indeed 'sided' (separate fuses for Left/Right), but they each cover front and rear sidelights at the same time. If a sidelight fuse goes, you loose that whole side of the car - front and rear sidelamps.
It looks like I have an issue with the wiring between the fusebox and the lamp unit. Big Cry Big Cry Big Cry The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #665069 25th May 2023 8:43pm
JMC
Posting an update here in case anyone in future suffers the same issue.
Today I dismantled the front of the car, pulled everything out of both footwells to access the wiring looms/fuse-box and even took the drivers headlamp switch apart down to PCB level. Despite this, I still couldn't trace the o/s/f sidelamp wire! It was giving me 2.6v instead of 12v and I'm putting this down to being the signal for lamp checking.
What this suggests is that the wire is intact, but whatever is feeding it isn't giving it a big enough portion! I wonder if there's some kind of ECU controlling the headlamps (aside from the LED controllers on the base of each lamp unit)? If there is, I couldn't find anything about one here (wiki), or on-line generally.
Anyway, after several hours of searching, I'd had enough. I've more respect for auto-electricians now though! Bow down
So, knowing that the headlamp unit itself wasn't faulty, I spliced into the other (n/s/f) lamp connector, took the sidelamp feed from there and routed a cable along the inside of the front bumper and into the o/s/f connector. Problem solved enough for an MoT, but I'm still troubled by the fact that it's a bit of a bodge rather than a successful resolution. Whistle
Post #667473 24th Jun 2023 10:46pm
Not a bodge, just a slight modification... Thumbs Up Pete
Post #667478 25th Jun 2023 12:38am
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
JMC
Having a similar problem you had but it is my O/S front LED indicator which is not working sometimes.
How did you remove the headlights without taking the bumper off and not damaging the lights? -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #709009 13th Jan 2025 1:41pm
JMC
As I said a few posts back, I made a 'slight modification'........ That's a technical term for inadvertently breaking off the lower mounting points! Embarassed Embarassed Embarassed The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #709036 13th Jan 2025 7:32pm
Giffer2018
I assume when you refitted them, the top accessible mounting points hold them securely and there is no movement/flexing when you are driving down the road. -----------------------
Post #709119 14th Jan 2025 5:50pm
