Home > Technical (L322) > Blower failed - DTC code B12FE-13 (28) FAN
Epson Green
Good morning all,
The main blower has not worked on my 2012 TDV8 since buying it 6 months ago. I have replaced the FSR but this did not fix the problem.
I have checked for codes previously on the GAP tool and until yesterday no code for the fan.
I now have code B12FE-13 (28 Fan - General electrical failure - circuit open. I have searched and can see B12 relates to Fan, but which one? And can anyone advise what the rest of the code relates to ie FE-13 (28?
I want to make sure this code is confirming the main blower under the centre of the dash has failed before I go about replacing it.
Many thanks
 Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #664674 22nd May 2023 11:04am
garyRR
I believe this fault refers to the fan on the infotainment, not the cabin fan.
https://www.fullfatrr.com/forum/topic64851.html
That said, it is know for the cabin fan to need replacement either due to blown bearings, or due to wearing out. 2015 Range Rover Autobiography 4.4 SDV8
Post #664725 22nd May 2023 8:27pm
Epson Green
That’s very helpful Gary, looks like I will be replacing two fans!
I am sure there is a good reason, but strange the failure of the main HVAC fan/ blower doesn’t give a code when it fails. Kevin
Post #664735 22nd May 2023 10:32pm
DrRob
Is that an easy fan to change do you know? Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664755 23rd May 2023 8:45am
garyRR
Both the infotainment screen fan and cabin fan are dash out jobs (because there's 2 screws holding the screen in which, in their infinite wisdom, Land Rover hid with the dash).
Post #664756 23rd May 2023 8:47am
DrRob
Genius designers Shocked Big Cry Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664758 23rd May 2023 8:50am
