Home > Technical (L322) > 2002 TD6 Replacement Engine Mounts
Stirlo
Australia
G'day from Australia.
I'm currently mid way through an engine transplant in my 2002 TD6 and have found the rubber in both of the engine mounts is perished / cracked so I'm intending to replace them while the engine is out and access is dead easy.
The TD6 diesel (BMW M57) has hydraulic engine mounts which are actuated by vacuum and cost circa GBP 165 each, whereas the same era 4.4 V8 petrol (BMW M62) has solid mounts which cost circa GBP 30 each. They both look to be dimensionally identical from photo's I've studied online.
I would much rather spend GBP 30 than GBP 165 (who wouldn't?), so was wondering whether the 'hydraulic' feature of the TD6 mounts really makes a noticeable difference to dampen engine vibration, or whether there will be negligible difference with cheaper V8 mounts.
So does anyone have any first hand experience installing V8 (M62) engine mounts in a TD6 (M57), do they fit and is there any noticeable difference in engine vibration?
Did BMW use similar hydraulic mounts in the early 2000's X5's fitted with the M57 3.0d diesel engine?
Post #661706 13th Apr 2023 1:22am
Stirlo
Australia
Follow up. I have now installed the M62 engine mounts in my M57 TD6 and can report that only a very minor vibration can be felt at idle speed which goes away as soon as engine speed increases. I’m content with the result and happy to have saved a fair bit of cash.
Post #665068 25th May 2023 7:37pm
GRANGEROVER
Germany
I did the same yesterday as the hydraulic version isn't available from Land Rover at the moment and it is unclear when or if they will ever be. Unfortunately there are also no aftermarket versions.
I did both sides on ramps in 1,5 hours. It can be done without unscrewing the brackets from the engine. In the manual this was described as it is a must.
Just be sure to have three extenders and two swivels for your wrench to get the bolts from the right side out (from the top). After unscrewing all bolts you can lift the engine and get both mounts out with a bit of wiggling.
I would do it with two persons to make sure to place the mounts right when lowering the engine again.
Post #691966 5th May 2024 2:05pm
GRANGEROVER
Germany
Another update regarding TD6 engine mounts. As I was fed up with the vibration while idling in the cabin with the M62 engine mounts, I went on searching for an alternative to the very expensive and hard to get M57 hydraulic mounts and bought some remakes from AliExpress.
I fitted them today and I am very happy with the result. The vibration is gone and while driving there seems to be no problem with the adjustment.
I bought these for 89€ per mount, which is much cheaper than any alternative I found:
https://a.aliexpress.com/_EwVxCGO
If the link doesn't work in the future search for KKB500480 on AliExpress.
Post #725292 28th Sep 2025 6:59pm
