![]() | Home > Technical (L405) > PHEV issues. |
| Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172
Just received a phone call from the mechanic. Due to the defect in the highvoltage heater,
| AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 190
My car doesn't seem to have the option to charge the battery from the engine 2025 P550e AB |
You can charge on petrol.
So essentially you’re saying when you’re not in save mode and you’re running the engine the battery should also charge? I did a 2000km trip recently and after the first 30km the battery went to zero and stayed that way. 2025 P550e AB |
It depends on many variables. If you turn onto the highway and drive 600km's at high speed with almost now braking then it does not charge at all, since all power is diverted to the wheels directly.
Interesting. So it certainly won’t charge the battery back up to 100%, regardless of distance driven, speed, or engine load? 2025 P550e AB |
I never tried, since its useless. With kwh at 20cnts on my present contract and 5 cnts from my solar cells, I avoid charging on fuel.
