Home > Technical (L405) > SDV8 strange noises |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
the rattle could be a loose exhaust shield.. ... - .- -.
13th Apr 2023 9:53am |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 83 |
Could well be the shield under the gearbox. Mine is making this noise so I'll be looking at this fix shortly.
20th Apr 2023 12:03pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
It is fairly common for the rear callipers to seize, just see if the wheel is hot after a trip, be careful it could be very hot... Pete
20th Apr 2023 1:17pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1239 |
Binding could be the transfer case needing oil replaced and recalibrated … it can bind and release on sharp corners due to the different wheel rates when cornering. Noticeable on things like pulling moderately out of a junction when on a sharp steering angle.
20th Apr 2023 7:20pm |
Oops double post V8 or else ... |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 121 |
The bang at low speed manoeuvring could the front lower control arm bush. Tends to happen more when going lock to lock, braking while turning like lining up for a driveway etc. Cam
28th May 2023 9:48am |
Foster2018 Member Since: 13 Apr 2023 Location: West Sussex Posts: 10 |
thanks all its under landy warranty so will be booking in with them! to investigate
25th Jun 2023 8:25pm |
