![]() | Home > Technical (L322) > Battery drain - 2011 5.0SC - new AGM battery |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8793 ![]() ![]() ![]() |
You don't "have" to code the battery in but it will take a while for the car to learn it has a new one, you could try charging the new battery overnight... |
AJT FF Member Since: 27 May 2023 Location: Bicester Posts: 8 ![]() ![]() ![]() |
Thanks. I’ve had it on a trickle charger and it’s now showing full.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3325 ![]() ![]() ![]() |
Could also be a failing alternator. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Usual culprits if not are a failing alternator as JayGee suggests, or the final stage resistor "hedgehog". 2015 Range Rover Autobiography 4.4 SDV8 |
Hi. just to follow up, I used my icarsoft diag box to run a voltage check with the engine on. I only saw between 11.8 and 12.2v rather than the 14.5ish I’ve been led to believe to expect. Would this point to a failing alternator? Thanks. |
With a smart charging system the alternator doesn’t put out full voltage all the time. Try switching on every electrical load and see if it goes up. 2012 TDV8 Vogue (L322) |
