Home > Technical (L322) > Low coolent level light on.
Barry
England 2012 Range Rover HSE Td6 Sumatra Black
Hi this is my first post.
I had the top hose popped off and called the AA he said it was not fitted correctly and refitted it its never came off since. To top the level back up he only had water no antifreeze ever since then I have had the coolent low level light on but the header tank is up to level.
I can see why the sender unit would be gone as it was fine before is it the case of it needs antifreeze.
Hope someone can help.
Barry.
Post #665515 31st May 2023 9:28am
JayGee
It would be helpful to know the exact model and year of your L322 as different engines have different cooling systems. 2012 TDV8 Vogue (L322)
Post #665516 31st May 2023 9:37am
Yep, fill out the car details in your profile.... Thumbs Up Pete
-Click here for Thread-
Post #665522 31st May 2023 10:26am
Barry
Hi sorry about the no profile think I've sorted it anyway its a 2012 td6 3ltr automatic hse sport with the pop up gear changer.
Hope this helps .
Barry
Post #665532 31st May 2023 11:32am
If it's a Sport then you are on the wrong forum, this forum is only for the Full Fat Range Rover Pete
Post #665539 31st May 2023 11:48am
JayGee
Hi Barry - you need the RR sport forum
https://www.rrsport.co.uk/forum/ 2012 TDV8 Vogue (L322)
Post #665540 31st May 2023 11:48am
