![]() | Home > Technical (L405) > Sunroof drain points |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 749 ![]() ![]() |
That small clear pipe exiting behind the drivers side rear wheel is the drain for fuel filler area.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1484 ![]() ![]() ![]() |
Thank you, that makes sense. I wonder were the sunroof drains to then?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35718 ![]() ![]() |
numbers 6 and 4 drF..
Thanks Stan, that's very helpful. I assume they discharge into wheel arch somewhere or maybe even under the car?? was going to make sure they were running free when I wash it. |
Thanks Stan |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 530 ![]() ![]() |
what's the best way to clear these out? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
I currently don't know, I am trying to figure this out. I am thinking a bit of strimmer wire that I am pretty sure someone said they used and plenty of time!! that is, if I can find out where they exit the vehicle in the wheel arch. I am slightly nervous of cleaning from top down just incase i dislodge the connection from roof to pipe as they appear to be fragile, so was going to go gingerly upwards (excuse the pun!) to avoid the joint and then do the same downwards and hopefully all will be good. |
would an air line be too fierce? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
