![]() | Home > Maintenance & Mods (L405) > SDV8 Oil Change with Castrol Magnatec Professional A5 5W-30 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2732 ![]() ![]() |
You shouldn't use an A5/B5 oil if a DPF is fitted. |
TJNZ Member Since: 17 Apr 2022 Location: Auckland Posts: 19 ![]() ![]() ![]() |
Thank you Graeme ... I did some checking on the Castrol site and it seems the following is the correct oil to use.
Seems like the incorrect spec oil was used .. probably 11,000km on wrong oil. Goes in Monday to have it replaced. 2017 L405 AB SDV8
Note that Magnatec Start-Stop is produced in both A5 5W30 and 5W30, being the A3/B3 A3/B4 that you initially referenced. It's still not a C2 specification though. |
Thanks Graeme yes they had been putting the A5 oil version in the car, but have acknowledged this is the incorrect oil and C2 should of been used. They will do a full oil\filter change on Monday. Hope nothing to adverse has happened. 2017 L405 AB SDV8
The A5 is better for the engine but not so good for the DPF. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
A5 is good for petrol engines
Magnatec Start-Stop A5 5W30 is A5/B5. |
