![]() | Home > Maintenance & Mods (L322) > 2011 L322 start stop button |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8696 ![]() ![]() ![]() |
Mine was a bit scratched, I ordered one from Aliexpress for about £13... it has been working for months and looks and feels just like the original. That's in a 405, I'm sure the 322 is similar...
AJT FF Member Since: 27 May 2023 Location: Bicester Posts: 8 ![]() ![]() ![]() |
Great. Was it easy to install? |
Geoff Hurst Member Since: 09 Oct 2021 Location: Sourhampton Posts: 10 ![]() ![]() ![]() |
Yes, check clip positions on new one, I used smallest 2 flat screwdrivers, gradually easing 1 in while fiddling with the clip with the other, slowly once one was released move to another, once all 3 unclipped, with fingers, hold firmly and pull using screwdrivers to further ease out, changing position every couple off pulls to keep it leveridged equally as not to click back in place, it will eventually pull out. Ensure small pins are perfectly straight and in position, dont over bend or you’re in |
Thanks. What could go wrong!! |
