![]() | Home > Technical (L460) > Indicators flashing at double speed on dashboard |
Crocs Member Since: 29 Jan 2022 Location: Ayrshire Posts: 109 ![]() ![]() |
I had the same and LR Assist did a temporary fix. Seems to be caused by a rear light fitment. Part now on order for proper fix. |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 792 ![]() ![]() ![]() |
Thanks. LR Assist arriving this afternoon hopefully. They appear exceptionally busy and I'm trying to avoid them sending the AA instead as I doubt they will know the fix. MY23 D350 HSE
For future reference, it was a software issue fixed by resetting the main body controller.
Andy355 Member Since: 21 Nov 2017 Location: London Posts: 45 ![]() ![]() ![]() |
I’ve got the same thing on right indicator dash double speed, left is fine but also someone in traffic pointed out that the right rear brake light is not working. This seems to have occurred since I did a software update (assuming it loaded successfully) |
The first thing the LR Assist person did today was check all my indicators were working, which they were, and then said it must be a software fault. As your indicator light isn't working it could be physical or software issue.
Thanks for the tips, never tried LR assist, previous issues the dealer lent me their demo car. Will see what they suggest. On mine the indicator is actually ok it’s the right rear brake light that has gone off but seems to be connected |
Often LR Assist know more about the problem than the dealer and will provide a temporary fix if they can’t fix it on your drive. They can also get you a replacement vehicle if yours needs to be off road, often quicker than the dealer. Some dealers insist on LR Assist attending before they will take on the job.
Thanks for the tip re LR assist they came and fixed a wiring issue |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1258 ![]() ![]() |
That’s for sure…. My dealer replaced the entire rear light unit …only took four weeks! ![]() I should add… there is a piece of sponge in the unit, which was recommended ( AT THAT TIME) for removal . Both sides. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
On mine they also removed the foam and are going to fit a new lamp unit also. They are coming back to me to super convenient |
maybe my dealer did the right thing then! Their front of house man needed a lobotomy anyway !
DJIT Member Since: 17 Feb 2019 Location: Hampshire Posts: 92 ![]() ![]() |
I had the exact same issue with my previous L460 as I drove it off the forecourt on collection. Put the indicator on to pull off the forecourt and had rapid flashing of the indicator. 30 mins back with the workshop to reset the lighting software and the problem was resolved and never came back.
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 417 ![]() ![]() |
I hadn't used my car for a couple of months and first drive this last weekend had the left indicator flashing quickly.
To be fair Andy , when mine went pearshape , there were none in the pipeline and I’m not sure they had discovered the software fix. Whatever stock they had , just vanished.
