![]() | Home > Technical (L322) > Dpf pressure sensor issue stop regens?? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
What specific error codes do you have ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Jimmies Member Since: 19 Jan 2022 Location: N.Yorks Posts: 24 ![]() ![]() ![]() |
PCM-Engine TDV8 4.4L
I've disconnected my dpf pressure sensor from all of the pipes and gentle blew backwards towards the dpf
Have you read the one or two very thorough previous threads on this subject on here? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I'll search now.... |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
The GAP IID will not give you a Kpa reading, only a voltage reading. Read the workshop manual....
