![]() | Home > Maintenance & Mods (L405) > Drivers Electric Head Rest Not Working |
Can you hear a motor whirring? Its on a worm motor so, you should hear the motor working at least... |
HenryFrancis Member Since: 28 May 2023 Location: York Posts: 12 ![]() ![]() ![]() |
Unnecessary quote removed
Then it maybe the wiring plug has pulled out of the headrest motor... Not very hard to get at if your willing to strip the back of the seat a little... |
I'm not scared!..... |
You might want to fill your car profile in sir… That was peeps will chirp in if they know which model it is you own and can help… |
As it’s a 13MY… Simply remove the lower seat back cover. A couple of lower elastic clips under the seat, I think you need to remove the two side covers to allow the lower back cover to pull outwards clear of the mechanism it clips over. Then the seat back lifts upwards and comes away in your hands! Then move the seat upwards and forwards, then get a torch and lay down behind the seat and look upwards inside the seat and you should see the wiring plug…
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
I had this exact problem with my drivers headrest, click but no movement and was indeed the multiplug had come adrift. I suspect when the seat airbag overlay loom had been installed they failed to clip the loom back into place.
You guys are legends.
Really glad to be able to help you sir… 👍 |
BurnsideDalesbreds Member Since: 02 May 2023 Location: Deepest Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Do they all have electric headrests on the drivers side? I have a 2014 Ab and I tried to move it manually but couldn’t, wondering if I’ve missed a button on the seat? 😂 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431 ![]() ![]() ![]() |
On mine the headrest is moved by pushing the seat back adjuster (on outer edge of seat base) up or down. Yours might have a separate button above the seat back adjuster. Only Range Rovers since 1988 |
Push the backrest button up/down to adjust the headrest sir… 👍 |
Fantastic! That’s it, thanks folks! What a schoolboy error 😂😂
