Home > Technical (L322) > 4 wheel alignment around exeter area
bastion
Looking for a good garage around the exeter area to perform a 4 wheel alignment after going over one too many pot holes. Now pulls slightly to the left.
Post #654891 27th Jan 2023 4:44pm
JayGee
Search Google Maps for 'Hunter' equipped garages. Be aware that the adjusters can become seriously corroded and seized therefore the garage may not be able to do any adjustment. 2012 TDV8 Vogue (L322)
Post #654898 27th Jan 2023 6:00pm
DrRob
Look up a Hunter place on www.alignmycar.co.uk
Or I can recommend a place in Hampshire Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #654922 27th Jan 2023 8:49pm
Dolphinboy
If you come up near Bristol at all I used an excellent bunch (Latvian Or Lithuanian)
https://bristolwheelalignment.co.uk
or nearer to you at Shepton Mallet, speak to Steve Norman (https://www.tandsnorman.com) about who they use. They do all the work on my RR and are second to none.
Post #654934 27th Jan 2023 11:49pm
bastion
There are not very many Hunter machine locally but some do use SUN PRISM Machine made by Snap On with the latest John Bean software.
Is this as good?
Post #659112 11th Mar 2023 2:53pm
damonky
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
I had mine done at bp tyres near newton abbot about a month ago on a hunter setup. https://bptyres.co.uk/ -----------------------------------
2011 4.4 TDV8 Vogue
Post #659667 17th Mar 2023 7:31pm
bastion
Just went to Marsh Tyres Exeter to get the alignment done, was told oh no you need four new tyres to do the test.
I thought you were measuring the wheel geometry not the tyres', but I am I wrong?
Got home checked the tyre tread all above the limit.????
WTF
Post #666582 14th Jun 2023 4:21pm
Glibbs
Devon 4x4 did an excellent job on mine. Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #666583 14th Jun 2023 4:40pm
JayGee
You don't need 4 new tyres. Just try Halfords or Kwickfit if you need it checked. 2012 TDV8 Vogue (L322)
Post #666585 14th Jun 2023 4:43pm
damonky
Worth going to someone good like devon 4x4 or bptyres. Went to get mine checked at national after replacing the front shocks. 3 attempts and it drove itself in circles. Back on a hunter rig and it was miles out. -----------------------------------
2011 4.4 TDV8 Vogue
Post #666590 14th Jun 2023 5:44pm
JayGee
Kwickfit used Hunter last time I had mine done (just front toe after track rod replacement). Often though it's not the kit the garage has but the ability and knowledge of the person operating it. 2012 TDV8 Vogue (L322)
Post #666592 14th Jun 2023 6:22pm
damonky
Very true. Hence i’ve found both the above to be very good. Should’ve read the warning sign that the office was full of monster cans at national 😂 -----------------------------------
2011 4.4 TDV8 Vogue
Post #666593 14th Jun 2023 6:30pm
bastion
Had the tracking done at bptyres. Very good service, but car is still pulling to the left.
The new print out of the tracking shows it should be OK.
What does that mean, any ideas?
Post #666691 15th Jun 2023 4:50pm
damonky
Not a massive expert, but could be 1 of the following perhaps that I've had in the past with this and other cars / vans:
0. They did not completely center the steering wheel when they did it ( always worth taking it back and asking them to check again) - is there an angle where it does drive straight? mine was about 15º off
1. different weights on the wheels( one ladened, one with none)
2. slightly different tyre pressures
3. One back brake calliper / handbrake binding slightly Check if one wheel is hotter than the other)
4. I did read somewhere here about worn rose bus joints on the rear, but I don't have any experience of that one.
Interestingly I had similar, was paranoid about it, but then went to France and it rolled to the right instead of the left because of the curvature of the road.
HTH -----------------------------------
2011 4.4 TDV8 Vogue
Post #666694 15th Jun 2023 5:08pm
bastion
Thanks for the thoughts5.
Funny I am off on a trip though Spain will be interesting to see if it changes.
Post #666704 15th Jun 2023 5:59pm
