Home > Technical (L322) > Alarm just started going off - Volumetric Sen
kooky_guy
Hi Guys,
Got home from work this evening and now whenever I lock the car, the alarm starts going off within a few minutes.
I'm not sure if I'm doing the right thing, but I looked at live values -> complete list -> BCM and all the last 8 triggers just state "Volumetric sen"
Does that suggest a fault with the sensor itself? Any idea how to stop it triggering? I'm only single clicking the fob so it shouldn't even be activating the motion sensors.
I need to work out how I can lock it tonight! without annoying the neighbours! 2010 4.4 TDV8 Vogue SE
Post #667132 20th Jun 2023 6:57pm
mjdronfield
Probably not much help, but have a look in the setup menu…
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #667137 20th Jun 2023 7:36pm
kooky_guy
Ah, missed that when I was perusing the manual.
Will give it a go. Thanks.
It's that or the alarm fuse! 2010 4.4 TDV8 Vogue SE
Post #667143 20th Jun 2023 7:51pm
kooky_guy
Well that didn't work. Will try the fuse next.
Looks like fuse 36 is the battery backed sounder. Fingers crossed...
Anyone able to confirm that the IID results imply a faulty volumetric sensor module? And what the part number might be? 2010 4.4 TDV8 Vogue SE
Post #667153 20th Jun 2023 8:59pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
I wrote with exactly this fault on here this morning. It's fuse 43 bottom row 12th fuse from the left in the glovebox fuse box. Ignore the blank/empty fuse spaces. Removing 43 killed my alarm. HTH. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #667160 20th Jun 2023 11:05pm
kooky_guy
Hi. Saw your post but didn't want to hijack it.
The face-lifts seem to have a different fuse. It's 36 on mine. At least it hasn't gone off for a couple of hours!
Been chatting to Patrick at Gap but it's a bit inconclusive. Apparently the triggers are an untested feature.
It sounds like it might be a faulty motion sensor looking at the trigger, but it still went off with them disabled so I'm wondering if it might be a failing battery in the siren itself - had this on my p38 when the battery back up died. 2010 4.4 TDV8 Vogue SE
Post #667169 20th Jun 2023 11:52pm
Dijit
Thanks. I hadn't realised the facelifts had different fuse boxes but then it's LR. Why make it easy?
Obviously I was concerned you'd got the wrong fuse but tonight I'm better informed. 😳 Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #667170 21st Jun 2023 12:04am
p38arover
Australia
On my 2003, a second press of the lock button turns off volumetric sensing. I need this when camping as when my fridge turns on, its fans disturb the air and set off the alarm. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #667178 21st Jun 2023 12:45am
kooky_guy
On the later ones, it's the other way aroubd (ie 2nd press enables the sensors), but even with the sensors not active the alarm is still going off every few minutes. At least, it was until I pulled the fuse.
I'm starting to wonder if the iid tool trigger events might be a red herring as there doesn't seem to be a time stamp on them. They could be historical events which is leading me back to the battery backed siren again.
Anyone ever changed the battery in one? I used to have a link to a thread for a p38 procedure, but that's long gone. 2010 4.4 TDV8 Vogue SE
Post #667182 21st Jun 2023 6:54am
p38arover
Australia
^^ I would prefer that method. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #667200 21st Jun 2023 9:11am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I had the issue of a random alarm sounding with my 2012 last year. I even once had it wailing when the car was actually being driven! Shocked Like you, I eventually resorted to pulling the fuse (36) and the problem was solved.
However, I later discovered that:
1. Locking the car with a door ajar didn't give any warning. Unless you watched the car when you pressed the fob to lock it, you could easily walk away with the car left open. The 'chirp' which would normally signal a non-locking event (door ajar) works off the alarm sounder.
2. I could no longer trickle charge the battery from the (white) towbar electrics plug. It appears that as well as the alarm sounder, this fuse also interrupts the main 12v line to the white towplug.
Recently, I've reinserted the fuse (36) and the alarm hasn't gone off....... yet.
I do wonder if a failing back-up battery was the cause of all the issues. Hopefully, it's totally dead now! I bet I get woken in the middle of the night now after writing this...... Big Cry Whistle Laughing The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #667250 21st Jun 2023 6:24pm
kooky_guy
Interesting.
I've ordered a 2nd hand sounder - can't seem to find a new one.
I'll see if that makes a difference- seems to be such a common unit that you can even buy batteries for it.
If the new one solves the problem, I'll try changing the battery in the original and refit. 2010 4.4 TDV8 Vogue SE
Post #667252 21st Jun 2023 6:37pm
My internal sensor was repeatedly causing the alarm to go off. Eventually removed the roof housing that contains the sensor and found a very large spider wandering around in it. Put the spider out to play elsewhere, reassembled the housing and never had a problem since. Might have been coincidence but….
Post #667254 21st Jun 2023 6:45pm
kooky_guy
I did think of that but it still goes off every few minutes with the sensors disabled.
I did give it a good blow though to see if anything appeared! 2010 4.4 TDV8 Vogue SE
Post #667260 21st Jun 2023 7:37pm
