![]() | Home > Technical (L322) > Steering Rake Memory fault |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
I've got this intermittent issue with the steering column adjustment. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35860 ![]() ![]() |
a battery dis-connect usually remedies a lot of electrical problems on the range.. |
Just disconnect the negative, for how long? (May fix my TPMS too!) Discovery 4 HSE
12 hours seems to be a ballpark figure adam .... |
Is that a joke? I can't not have the car available for 12hrs!
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Over nite? OK you will have to re-connect am, but you could pretend you have a 11my with a flat battery ![]() |
+1 for over night... |
I disconnected the negative terminal that's attaches to the body by the battery, as this looked like the easiest method.
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 ![]() ![]() ![]() |
Mine doesnt even move at all!!!! No memory feature. I woud assume this is a standard feature? Also seats have memory but dont "settle" in the default position when ignition is turned off. Is this right??
FWIW I have found the 12 hours thing to be a myth. The main issue is to ensure all modules have no residual charge left in capacitors etc. Best way to achieve this is to disconnect the battery earth lead and then short it to the positive lead for 30 seconds. I actually do this through a standard 21w indicator bulb as it's a little less brutal.
Maybe you had best explain EXACTLY how you did that |
this extract from rave might help...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3958 ![]() ![]() ![]() |
I read your post and mine started behaving in exactly the same way ![]() Please let me know if you get a result disconnecting the battery ![]() |
