Home > Maintenance & Mods (L322) > Rust
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Rust
Afternoon all,
Just trying to head off some major expense next year as when presented for MOT the other day mine failed on a couple of silly things but the tester highlighted corrosion on the front and rear sub frames and rear lower wish bones (they are only advisory at this point as not effecting structural rigidity)
so...despite liberal coatings of lanoguard every year the tin worn has found a way in Crying or Very sad what do you all recommend to try and rectify this (I'm thinking a good brush down to get the worst off then some sort of rust convertor then.... (over to you))
Cheers
Post #666529 13th Jun 2023 4:53pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I used to work in the offshore oil and gas industry, the standard rust converter / metal protection was 'aquasteel'. It's absolutely amazing, it turns rusty steel into a protected glass like coated item.
https://aquasteel.co.uk/ BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #666539 13th Jun 2023 8:26pm
bradww
Neutrarust-661 seems to do a similar job too.
Easy to apply but don't get any of it on you.
I've read elsewhere of threads and positive feedback using Neutrarust+Lanoguard and also the use of POR-15.
Post #666570 14th Jun 2023 9:48am
Discofish
Thanks for the recommendations both, will have a look at them and then when the truck comes back I'll be lying in the gutter scraping and painting Smile
Post #666587 14th Jun 2023 4:55pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I can vouch for Aquasteel too. I had advisories for the same areas previous year, then last year I wire brushed them down and used Aquasteel. No advisories for corrosion this years MoT.
Post #666594 14th Jun 2023 6:38pm
bradww
another alternative to throw into the mix - KBS coatings; RustSeal.
KBS do lots of special use paints. They are from the US. There are UK resellers online..
I've recently bought some KBS VHT primer and paint from them. It arrvied last night by courier.
Its for my exhaust (refurbing a replacement for my missing OEM back box).
The replacement BB was heavily rusted/paint peeling off. Have prepped it with a cup brush/drill combo and intend to prime/paint over the next few days if the ambient temp drops a bit.
https://www.kbs-coatings.com/rustseal.html
https://www.kbs-coatings.com/kbs-three-step-system.html
Post #666636 15th Jun 2023 8:29am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I have 20+ years in the O&G offshore industry and I will only use Aqua Steel as a rust converter.
Jim
Post #666805 16th Jun 2023 9:15pm
bradww
Worth noting that Neutrarust 661 is MOD approved too.
Post #667224 21st Jun 2023 2:10pm
JayGee
MOD approval could easily mean it's the cheapest option..... 2012 TDV8 Vogue (L322)
Post #667225 21st Jun 2023 2:31pm
gettingold
I see the aquasteel can be painted over (or not). If you choose to do so what would you paint it with?. Hunt for a L405 is on.
Post #667230 21st Jun 2023 3:05pm
AJGalaxy2012
Anything you want, may garden gates I did Aquasteel followed by Black Hammerite Smooth. BMW i3 Electric Car
Post #667258 21st Jun 2023 7:32pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
No one has mentioned Hydrate 80, the rust treatment I and several others on this forum use.
I have done a bit of research and looked at all the marketing bumf of the converters mentioned in this post.
"complex organic iron compound by the unique deoxygenating agent" is typical claim by all of them, so without any scientific basis I suspect that they may well be the same or very very similar chemicals.
Had I not already used Hydrate 80 I would choose between them based on price as I see little if any difference between them from the marketing material and the technical data published on their websites.
The one thing I have noticed is that they differ from the old rust converters by not being washed off.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #667267 21st Jun 2023 8:52pm
Ennoch
If they convert it to black then it's pretty much all based on phosphoric acid, it's the other stuff that's what makes it more or less durable as a final surface.
I've used Hydrate 80 and it is good stuff but I don't subscribe to their suggestion that it doesn't need over coated. Personally, having done a ton of work on my impreza, I get it back to bright metal as much as possible whether that's with a convertor gel or sanding it back first. I then put on a layer of the H80 once I've got it back to as much good metal as possible. Yes it converts rust to an inert substance but only the surface. Some people make the mistake of putting it over loose stuff and that just lets the rust creep back underneath. Depending on the area I will then sometimes sand the surface again so that the H80 only remains in the pitting, and then top coat with an epoxy primer, followed by a top coat (epoxy isn't UV stable). Everyone seems to have a different way of doing things but the key one is mechanically or chemically removing the rust rather than converting it. If you can remove the parts and soak them in a citric acid bath then do so, especially if you can keep the solution warm with a fish tank heater. If you want a cheap paste to put on as a convertor gel then wallpaper paste and citric acid crystals with a little water to make a decent consistency is basically all that BH Deox Gel is.
Post #667299 22nd Jun 2023 12:13pm
AJGalaxy2012
I dont know the tech side of Aquasteel I can only vouch for it from my experience. Offshore in the oil and gas industry conditions are horrendous for steel, it rusts heavily in a very short time. A treatment of Aquasteel stopped the corrosion and gave a good surface finish that could be left or painted over if a different colour was needed. The protection lasted for years literally. BMW i3 Electric Car
Post #667338 23rd Jun 2023 6:18am
