![]() | Home > Maintenance & Mods (L322) > Windscreen Replacement |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
They may have trouble removing the wipers and try to fit the screen with them and the plastic scuttle in place, this is not a good idea...!!
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 114 ![]() ![]() |
Thank you. I will insist that the wipers come off.
A bit late but yes, just pulls off, after removing the few trim clips, then there are other clips behind it and it's these that tend to break....
Thank you. I think I’m going to end up buying some clips.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Unfortunately the clips that break are part of the scuttle panel so can't be bought independently of it. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Yep, as Dan says the other clips are the actual scuttle itself...
