Home > Technical (L322) > Height Sensors Am I doing it Wrong?
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
I changed the front left height sensor a couple of months ago and had to take the whole bracket off as the 2 bolts holding the sensor to the bracket just turned round in the thread as I was trying to unscrew them as if the brass thread in the plastic was turning as well
Well b$$$$er me and call me flopsy, I have just tried to change the rear left and I can get both bolts started quite easily but, while they will turn, they won't actually come out of the thread. Am I missing something fundamental or is it just bad luck, crappy parts and I need to get a hammer and chisel onto the darned thing, smash the plastic and then grip the threaded part? Actually I'm doing the bushes on Sunday so I should be able to get to it then but the temptation to go all mediaeval on it is very strong.
Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #665045 25th May 2023 6:00pm
mjdronfield
I had exactly the same issue when I did my front left. Ended up cutting the old sensor off the bracket. Luckily I found bolts to go to the bracket, so fastened new sensor to old bracket with those. The bracket is over £100 from LR… I know as I rang them…. Though I think some aftermarket sensors might come with the brackets which would make the whole job easier… but with this fix, it’s best to stay with LR height sensors if you can.
The brass insert just spins in the moulded plastic…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #665047 25th May 2023 6:35pm
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Had exactly the same problem, Dremel to the rescue I'm afraid!
Post #665052 25th May 2023 7:24pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Same here; 30 mins under the car with a junior hacksaw to cut the sensor off the bracket. TDV8 4.4 2012
Post #665072 25th May 2023 9:00pm
Goldstar
Still haven't done this yet-think I'll just smash the sensor off with a chisel and then attack the bolts. Any reason why I shouldn't do it this way?? Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #667804 28th Jun 2023 7:28pm
mjdronfield
You can just unbolt the bracket with the sensor attached, and then attack it off the car. You need the bracket so don’t damage it. No reason to be faffing about laid on your back etc….
Unless you meant once you’ve unbolted it….. that’s what I did, though I did wreck the bolt heads trying to undo them. I replaced with nuts and bolts.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #667813 28th Jun 2023 8:58pm
Goldstar
Thanks, I will put that on the agenda for tomorrow afternoon - be a nice contrast to school speech day in the morning... Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #668563 7th Jul 2023 9:36am
Goldstar
By the way I ended up using a powerfile sander on the bolt heads and 10 mins later it was off. Removing the bracket on the rear is a bigger job, using the powerfile made it a doodle once i got the angle right. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #691184 24th Apr 2024 8:16am
