![]() | Home > Technical (L322) > Engine Management Fault |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3337 ![]() ![]() ![]() |
We need codes to make any diagnosis. A generic code reader may help but any competent garage should be able to do this for you. Best still is to get yourself a GAP IID tool and DIY. 2012 TDV8 Vogue (L322) |
Byg Nyge Member Since: 31 Dec 2022 Location: Newcastle Upon Tyne Posts: 31 ![]() ![]() ![]() |
I have a ThinkCar Diag 2 I did a diag last wednesday and couldn't see anything pertinant, I'll have a look tomorrow. it's going in for a service on thursday would they do a diag on it as a matter of course? |
Not unless you ask them but they should reset the service interval so will at some point plug in a diagnostic tool. 2012 TDV8 Vogue (L322) |
The saga continues - went in for service yesterday (Thursday) Everything ok until they changed the fuel filter. cannot be driven, fuel pressure too high P0088? fault code,never had that one before. Garage at a loss as to why. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Fuel pressure too high would suggest the high pressure fuel pump being an issue or a faulty injector (or two) and may explain the problem occurring under load or randomly.
All sorted, looks like the PCU? had a brain fart and threw up the code. Battery disconnected overnight fault gone, put 100 miles on it this morning round the doors and lanes and a motorway jaunt no problems. Fingers crossed. |
And back in the room, all good for a few days and the fault re-appears, took it to a local LR Specialist and he used his super dooper computer and reckons the probable fault is the EGR valves all caked up and sticky (a bit like meself!) they're going to do an EGR delete and re-map and he reckons that will do the job. Fingers crossed. |
