![]() | Home > Maintenance & Mods (L322) > Silly Question? Brake Fluid |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Your brake fluid reservoir has a max marker near the top of the reservoir before the neck. 2015 Range Rover Autobiography 4.4 SDV8 |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Thanks very much Garry I'll have another look. Have to say it's not in a very accessible position and it does need topping up then.
I find that when you put the stem back in the level rises somewhat, so fill a couple of millimetres below the max marker. Once you put the lid back on, it should show nearly full.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
As an additional suggestion :
Good point, well made sir... |
Thanks to everyone. I found the max line as said but wasn’t able to see the actual fluid level due to yesterdays light here. All was well when I rechecked and not therefore responsible for my dashboard warning lights. Got it in a garage next week for them to check them out.
