![]() | Home > Maintenance & Mods (L322) > AC clutch question help. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Anyone?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Yes, mine does say through IID. And with the blower down low with the windows open and engine idling, when I press the A/C button, I can hear the clutch engaging. 2015 Range Rover Autobiography 4.4 SDV8 |
Hmmm, the engine note changes when I press "on", but it always says "off" when looking at IID.
It may mean that's simply not monitored on your car.
I can clearly hear the additional load when turning the AC on, no doubt about that.
I would get a garage to place a pressure tester on the A/C system. They can confirm if there's a leak, but they can also confirm if there's too much pressure on either the high or low side of the system.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Most garages these days have an AC machine and will test the system for free and charge if it needs a refill or other work. 2012 TDV8 Vogue (L322) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
You can test the pressure with the Gap iid. John
Pressure on the GAP says something like 16 (cant remember the units |
Oh and it was charged on a garage machine that tested for leaks on Tuesday.
As an update (and more help required) I tested it this morning. 25c outside temp.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
20 bar is way too high pressure for normal operation. Looks like there's possibly an issue on the high side, either expansion valve blocked/freezing or a compressor problem.
I would suggest the Pressure Control Valve on your compressor has failed (common on a lot of cars).
Thank you. Garage job or DIY?
