Home > Maintenance & Mods (L405) > AUTO BRAKE HOLD, how to switch off permanently
Dan_Veluwe
Netherlands
I don't know if it bothers you as much as it annoys me.
Turning the car in the street and the 'auto brake hold' engages..
You have to kick the accelerator to get it of asap, and you jolt forward.. ..not ideal.
Same thing : slowly backing up on an incline.. .. it blocks the parking brake 'auto hold'..
Nice for disabled drivers, but for the rest a nuisance..
Can't find a procedure how to kill this feature off permanently..
Who knows how to reset this monkey.. Rolling Eyes I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
PHEV P400e Hybrid Autobiography Loire blue= SOLD
D5 SD4 HSE Lux Corris grey = SOLD
D3 TdV6 HSE Lux Vienna Green =SOLD
P300 F-Type 2018 Ultra Blue = SOLD
25t F-Pace 2020 Loire Blue = SOLD
Post #668589 7th Jul 2023 2:42pm
Gremlin500
This behaviour is only on the PHEV vehicles such as yours, I don’t think it can be programmed out with an iiD tool, but others more knowledgable may advise, hopefully. Whistle
But why not simply push down the switch to release the EPB before you drive off?
Perhaps it’s different on the PHEV, but moving off with the EPB applied (say whilst executing a 3-point turn on a heavily-cambered road) is normally quite smooth if you are gentle with the throttle.
I guess it could be a little unnerving if you are really close to another vehicle. V6 Vogue - “Less is More” - less to go wrong!
Post #668786 10th Jul 2023 10:44am
Dan_Veluwe
Netherlands
Hi Gremlin, thanks for your reply.
The EPB is off. What happens is : I'm driving, send by the satnav into a dead-end facing bollards making the rest of the road a bicycle lane. I can only backout or turn. Both sides parked cars with two slithers on both sides to put the nose/rear of the car. Then when I slowly approach the curb and stop, the brake applies..
To get going, I need to pres the throttle to 'override ' the 'parking brake'. Maybe I should try to disengage it with the handle ? I find it a nuisance. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Post #668791 10th Jul 2023 11:11am
Gremlin500
Hi Dan,
Did you check out the mode of operation of the EPB in the LR iGuide?
See here: https://www.ownerinfo.landrover.com/
You should be able to release the parking brake manually by depressing the switch in the centre console?
Hope this helps. V6 Vogue - “Less is More” - less to go wrong!
Post #668800 10th Jul 2023 12:00pm
Dan_Veluwe
Netherlands
@Gremlin 500.
I did check it before, but couldn't find it.
But using the phrase "EPB" ( what the describe as a switch in Dutch..), I could.
There is a method to permanently disable the "auto handbrake" function.. Thumbs Up
Confusingly there are two methods to switch it off permanently.. Rolling Eyes
Post #668801 10th Jul 2023 12:11pm
Gremlin500
Result! Very Happy Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #668806 10th Jul 2023 2:05pm
