![]() | Home > Technical (L322) > Duel ride height |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2767 ![]() ![]() |
The flashing access and normal height LEDs indicates that a problem had occurred that now requires the operator to confirm the desired height. Stability control warnings generally trigger safe height which has access height as maximum height. Restarting after such a fault can leave the suspension module wanting to be told which height is now required.
Toze63 Member Since: 20 Apr 2023 Location: Ewhurst Posts: 4 ![]() ![]() |
Thanks for the quick response Graeme.
The fault codes need to be read to provide the starting points. |
Ok mate thanks |
Ok so I checked the inter cooler pipes on top and whilst one was spongier than the other, both were free of splits or any holes. I then noticed one of the elbow hoses on the rail was kinked and the jubilee clip had dislodged under the elbow. Refitted and fingers crossed all seems to be working fine even uphill under acceleration.
