![]() | Home > Technical (L322) > C1a13-64 new compressor fitted |
James855 Member Since: 15 Jul 2023 Location: Nottinghamshire Posts: 7 ![]() ![]() ![]() |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Hi, is it possible that when refitting the replacement compressor the pipes have been crossed over? I seem to remember having similar issues after rebuilding the compressor on my TD6 a few years ago and getting quite frustrated until I finally realised what I had done. You may have already considered this but if not it may be worth a look.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Is it the exact same compressor? If a different brand you need to tell the car via IID |
I think he’s got the pipes right but I’ll double check tomorrow. |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 175 ![]() ![]() ![]() |
There are 2 diff brand of compressors. It looks as if you have fitted the other one.
The replacement he got was meant to be hitachi but it’s slightly different to the one he’s taken off where the exhaust valve is. |
It’s meant to be an hitachi I checked with the IID and reflashed the software |
Update
Basically started from the beginning. New compressor still on the truck cleared faults with iiD tool. Started the truck and compressor started like values in the picture. She’s sat on bum stops but wasn’t lifting at all. 2 lights on the suspension control illuminated the moment I go to adjust height it throws suspension fault and says special programs turned off. Fault is also in the pictures. Next step is swapping my compressor onto the truck which is fully working to see if it gives the same faults so I can rule out the new compressor.
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 100 ![]() ![]() ![]() |
Good afternoon James, I've just gone through a similar thing, mine kept doing the same, I bought a compressor off eBay, then in 2months the fault came back and I ended up buying a second OE compressor. It still did it, in the end it turned out to be the steel air tank. It had a very slow leak due to it being rusty, so a new one bought and fitted and all is good with the suspension now. I think the only reason the eBay unit failed is because probably it was running constantly every journey.
