![]() | Home > Technical (L322) > Towbar Electrics 7 Pin |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Not sure if you can buy the plug that fits the boot socket on its own.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I can confirm that the Gap IID can do the configuration you will have to tell which pin unit you have 13 or 7 pins which will disable the parking sensors and fog. 2017 SDV8 4.4 silicon silver AB
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1000 ![]() ![]() ![]() |
thanks chaps, much appreciated ! |
Steve RR Member Since: 28 Jan 2013 Location: Ayrshire Posts: 16 ![]() ![]() ![]() |
What about the trailer stability assist? Is this active or needs turned on too?
