Home > Maintenance & Mods (L322) > tail gate
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
tail gate
Hi All
New here so first post new to L322 ownership pick up a 2008 Vogue SE TDV8
First question of many should the tail gate lift by its self when open button pushed
second question parking sensors when reversing dont seem to work but the button on the dash flashes Fault ?? and the reversing cam screen stays on once out of reverse have to push back button to close it
Thanks all
Post #669344 18th Jul 2023 6:26pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Tailgate is not automatic. Just unlatches off the button.
Needs diagnostics to identify the parking sensor fault. Reversing camera issue could be CANbus related, wiring, all sorts. Diagnostics again may help diagnose. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #669345 18th Jul 2023 6:36pm
dazk2001
Thanks just wondered if the gas strutts had gone as have to lift the door up
would a diagnostics tool help diagnose the reversing problem thinking of the gap IID as sure it will be worth the investment as not going to be my first fault
Post #669365 19th Jul 2023 4:34am
p38arover
Australia
Very likely the struts have lost pressure. They are cheap from aftermarket sources and quite easy to replace. The hardest part is holding the tailgate open while replacing. Get an assistant or a length of wood.
How are your bonnet struts while you are doing the tailgate? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #669366 19th Jul 2023 6:20am
JayGee
You have to lift it but it should not take much effort and as others have said the struts are cheap and easy to fit. Also check the bonnet struts. A flashing fault on the parking sensor system generally means a wiring fault on the sensor which is due to their terrible design. A GAP IID tool will tell you which one it is. A fix requires removal of the bumper so hope it's a rear sensor as the front bumper is a PITA to remove. The rear cam does stay on for a bit once drive is engaged but should go off eventually 2012 TDV8 Vogue (L322)
Post #669371 19th Jul 2023 8:56am
dazk2001
thanks fo rthe reply
so sounds like the gap iid tool is worth having
Post #669427 19th Jul 2023 5:24pm
Yep, defo worth it and always worth a good price second hand on here.... Thumbs Up Pete
-Click here for Thread-
Post #669431 19th Jul 2023 5:31pm
dazk2001
can you point me to the for sales
Post #669452 20th Jul 2023 5:07am
p38arover
Australia
^^ See https://www.fullfatrr.com/forum/for-sale-wanted-vf11.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #669453 20th Jul 2023 6:52am
