Home > Maintenance & Mods (L405) > oil cooler
V8Russ
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
oil cooler
Hi all.
Just joined the forum after buying a 2017 ATB SDV8.
I took it to JLR for a pre-warranty inspection today and they picked up on a few things before I can proceed.
Oil cooler leaking, rear brake pads, steering column UJ gator split and ACE front bushes worn.
How big a job is the cooler and steering gator?
Any suggestions of independent garages around north east Hampshire?
Also can I do a bi-yearly oil change using a vacuum pump? No dip stick so where does it go?
How easy are rear pads to change and what makes are best?
Cheers
Post #669599 22nd Jul 2023 7:07pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Oil cooler cost me £600 last year fitted by Indy, don't know about your other bits.
2011 4.4 Vogue RR owner
Post #669613 23rd Jul 2023 12:07am
DrRob
Take it here www.glenrands.co.uk and tell Ross /Mike I sent you. Avoid main dealers at all costs!
Ross will give you the option of using OEM parts from Advanced Factors or Genuine. Latter is same but in a Land Rover box and will be double the price of an OEM. I have an oil cooler fitted from Advanced.
The team there will look after you Thumbs Up
Loan cars, home collection or local station drop off Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #669627 23rd Jul 2023 8:40am
TPhipps
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Lower gaiter quote @ £345 main dealer
Post #669634 23rd Jul 2023 11:33am
caymanblack
&t=272s
&t=1s
I bought my rear pads from the main dealer £125 + vat. overfinch modified
Post #669635 23rd Jul 2023 11:42am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
My oil cooler cost £1.2k at an Indy. Apparently things took a lot longer to remove than they anticipated, I was quoted £600 - £800 which they regarded as an estimate rather than a quote.
Pads are an easy change, I just fitted Brembo front and rear pads and discs. On the rears you do need to set the parking brake into service mode and there are threads and tube videos available on how to do that.
I do annual changes on the engine oil even though I only do £2k. Its a good way to keep the turbo's working to do regular and low miles oil changes. I use a sucker on the oil changes and the important thing is measure the oil out and add back the same amount as the oil indicator on the dash might not cooperate with a fresh reading until the car has been run a while. Then when its run you need to wait half an hour before you can access the oil level reading. No dip stick can be a real ball ache.
Post #669649 23rd Jul 2023 4:22pm
V8Russ
Cheers all.
Post #669652 23rd Jul 2023 4:43pm
DrRob
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #669655 23rd Jul 2023 4:51pm
V8Russ
Emailed Glenrands. Fingers crossed for a competitive quote.
Post #669659 23rd Jul 2023 5:32pm
